The message indicates the failure in programming the IOB as a VLAN is added or removed to/from the I-SID. Lower the severity to narrow the cause of failures. The cause could be in the status change of IOB, the PSI library or the low on memory in the system.
Retry the configuration so that the IOB can get the new Flood group index.
Debug-Summary
Failed to update the PSI of VLAN, %vlanName% to the PSI of %ownerName% when %info%.
| Name | Type |
| vlanName | String |
| ownerName | String |
| info | String |
